  #69 (permalink)
Old 07-26-2008, 07:21 PM
jasonh's Avatar
jasonh jasonh is offline
Default Re: Beefed up ignition??
ok here we go. First off,
CDI test - help verify my results
is where the following is from.
Originally Posted by jasonh View Post
Magnetos output AC.
Yes, they are called CDI's as in capacitor-discharge-ignition. My beef currently is I cannot find anything about a real CDI that only has 2 wires. Everything I can find basically says this:
A CDI will take a constant power source and keep a charge inside. Then it gets a pulse signal from the motor and releases all that energy into the coil which then steps up the voltage big time and that gets output to the plug which has your lovely little spark.
We only have a power and ground on these, so I don't see how exactly they would work short of just acting like a normal coil and sending out a zap every time the magneto spins around and makes a pulse o' power.
Not to mention, how are these "CDI's" so darn cheap? I can't find cheap Chinese CDI's for under $50-75.
Right now I'm actually wondering it basically charges on the + pulse from the magneto, and then the - signal from the magneto is the extra "trigger" pulse. That seems like it could be logical, but I can't seem to find any info on anything similar.
Any ideas on what kind of ignition mowers use?
So I've been Googling like mad, and I think I may be on to something. It kind of looks like our ignition system is similar to the Briggs Magnetron system, but the trigger coil is our magneto. Which brings me around full circle wondering why the heck this test doesn't work. Some info on the Magnetron system:
The Magnetron Ignition System - Learning Activity
Timing is Everything - Basic Kart Ignition Explained, Part 2 - Article by John Copeland (first half of article)
Hopefully this helps us get somewhere with our ignition systems...
