  #68 (permalink)
Old 07-26-2008, 07:15 PM
jasonh's Avatar
jasonh jasonh is offline
Default Re: Beefed up ignition??
I've been doing a little research on stuff we could use for these motors, so I figured I'd post what I've found so far. Sorry about the organization, I'm just pasting excerpts from some posts I've made. Some may be new info, some old, who knows.
Originally Posted by jasonh View Post
I've been looking for a replacement CDI, but ours is not the traditional CDI. Most CDI's have a constant power source and constant ground, and it receives a "fire signal" coming from a secondary magnet/coil (or hall-effect sensor, or optical sensor, or even mechanical points) on the flywheel...in other words they use a minimum of 3 wires, unlike our 2.
Tj, the only problem with that CDI you posted, is our motors don't have a separate trigger coil. Most CDI systems have a charging coil and a trigger coil on the motor. We just have a single coil. So ours works a bit differently. I'm still trying to figure out exactly how...we may have something similar to the Briggs Magnetron system, but I haven't verified that yet. Once I get my new magneto and CDI in and I verify the bike works, I might rip into my old CDI and see what's up.
I know I have posted an animation and other info on the Briggs-type system, I just can't find it right now
