  #13 (permalink)
Old 01-22-2008, 05:04 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: Carb pictures how to
push it together. you can do this on the bike if you got the room sometime you will have to remove the aircleaner to mount the carb on a tight fitting frame. after pushing it together just a little twisting to help spread the silicone and aline up the casting seams on the carb and the manifold tighten the bolt and TADA.( I polished off the seam fooling around with the polishing wheel and never mind the weird fitting its for a boost bottle and I wanted to try one so I made one. I would recommend a tuned pipe money better spent and thats my 2-cents but they don't hurt anything and if you want it to look cool sticker and all go for it. I did find the engine will idle at a much lower setting on the idle screw and the thing seems to run smoother but top end nada. My final thoughts on the boost bottle is don't waste your time on them.
motorized-bicycle-carburetor-install-rebuild-carbpict018.jpg  motorized-bicycle-carburetor-install-rebuild-carbpict019.jpg
Last edited by Norman : 04-16-2008 at 09:47 PM. Reason: bogus boost bottles my 2-cents.
