Re: Carb pictures how to adjusting the float for the fuel level this is something to do only if you can't get it to stop flooding or over filling the bowl with fuel. If you ruin it you most likely will have to get a new carb. I haven't checked on parts at the cycle shops. I'm showing where to bend it I don't recommend bending the tangs as it would be hard to bet them the same and they probably are not the same anyway. messing with fuel level in the float bowl will affect rich to lean to a degree how much on this thing I don't know. lower fuel level equals learner mixture and can starve engine and you might burn a hole through the piston. something to think about. Do a plug check when messing with the carb. |
