Old 07-25-2008, 08:45 PM
Jemma Hawtrey's Avatar
Jemma Hawtrey Jemma Hawtrey is offline
Default Re: Chainsaw masacre
Hi
If I am right then that second port is a stratification system port...
its one of the methods use to make clean burn 2-strokes and it was used on the Zenoah engine as fitted to GEBE's in the past.
Im not exactly sure how the system works but I *think* the idea is to dilute the exhaust gases and also to form an air block so the mixture in the crankcase at that point cant vent to air either way - which maybe something to do with the reason why the little Zenoah kicked so far above its weight.
Its just a suspicion. It would help if you had a manufacturer for the motor so research could be done
Jemma xx
"....Look, no pedals... *thud*..." The mating call of the motorized-biker.
"RetroEagle" - 32cc Two-Stroke, Piped. 35mph on #13 gear. Reversed stem with springer fork.
