Re: Engine top end rebuild and an engine stand 1. got the studs in and the base gasket in place and the little wooden helper inplace I also cleaned the crankcase in the solvent tank blew it out with compressed air and shot some oil on all the bearing surfaces no pic. on that as you can do it with out pic.
2. oiled piston and cylinder indexed the rings so I won't break a ring and the cylinder almost falls in place.
3. I spray a very light coat of cheap aluminum spray paint on the head gasket before I install it. No I didn't paint it there I did it out side. |
