Re: Engine top end rebuild and an engine stand How the rings fit on the piston and where the ring locator pin are and how the rings fit etc.
Pulling out all of the studs I'm doing this to make it easier to clean the surface where the cylinder base gasket will go the old one is toast when you clean the surface don't gouge the surface. I use a gasket scraper and the dremels wire wheel. |
