  #9 (permalink)
Old 01-25-2008, 11:16 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: Engine top end rebuild and an engine stand
I'm using a .004 thinner head gasket bumps up the compression a little.
put shop rags in place before you pull piston completely out of cylinder that way you won't loose anything in the crankcase good idea for rags when working on the rings or piston so stuff doesn't jump into the crankcase when you aren't looking (gremlins you know)
motorized-bicycle-engine-top-end-rebuild-70ccenginepic024.jpg  motorized-bicycle-engine-top-end-rebuild-70ccenginepic025.jpg  motorized-bicycle-engine-top-end-rebuild-70ccenginepic026.jpg
