Old 01-25-2008, 10:13 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: Engine top end rebuild and an engine stand
use vice grips to work arm to help get the cable out of arm same when you go to put it in, saves your fingers.
Here is whats under the clutch arms cover a ball that alot of you loose and a short rod the ball goes in first then the rod and grease everthing before you assemble it and note the screws the long screw goes on top at the back and doubles as the front chain guard mount.
motorized-bicycle-engine-top-end-rebuild-70ccenginepic005.jpg  motorized-bicycle-engine-top-end-rebuild-70ccenginepic006.jpg
