Re: how to redrill main jet? It was stock before I drilled it .70mm and now I have it drilled to .85mm or .90mm. I purchased a set of drill bits from a hobby shop and they were ranged from #70 to #52. I found the bit that was the same size as the main jet hole and then went to the next bigger size. When I put the next size through it didnt seem to make the hole any bigger so I went up a few more sizes.
I will try to move the clip to the top notch and see how it runs. |
