Old 07-14-2008, 09:31 AM
MrLarkins's Avatar
MrLarkins MrLarkins is offline
HS Math Teacher
Default Re: Wireing kill swich and the chain keeps falling off
Originally Posted by filestyle1 View Post
inside your kill switch wire you have two wires - black wire to ground and the other to connect into the blue wire from the motor! as far as the chain coming off - do you have your tensioner on correctly and adjusted right ? and how about your rear sprocket that you added , is it true and straight ?
i thought that 'other' wire (mine's red) attached to the white motor wire?
my cdi (I assume that's the little black box) has one black and one blue...and I connected that black to the motor black and that blue to the motor blue...my kill switch has a black and a red and I grounded the black to the frame and connected the red to the white. and my bike went 300 miles with a working kill switch
