Re: Tanaka 32cc Nitromethane Experiment Just be very careful mixing alcohol based fuel with nitro to your two stroke mix....alcohol need roughly three times the volume to run as rich as gasoline. Too much and you are running very lean. Nitro effectively adds oxygen to the fuel causing it to run leaner still. Also, when mixing the airplane fuel, do you account for the 15% lubricant when adding your oil to the mix?
Tread lightly, as you seem to be doing, but be aware the "edge" is ahead in the fog you are travelling through.
