Re: NO Start hey 08; for the carb. take off air cleaner, look inside, is it moving all the way up and all the way down, if try to adjust cable at carb and twist grip. is the petcock open, does gas come out if you pull gas line off at carb? if all is good go to elec., disconnect kill switch. after that you can pull spark plug, pour in a little gas. put in plug and pedal..good luck and let us know mitch |
