Old 06-29-2008, 01:53 PM
MotorbikeMike's Avatar
MotorbikeMike MotorbikeMike is offline
Dealer
Default Re: GXH50 vs Chinese Clones
Hi Guys, More info on the Honda.
As I cannot seem to find spec pages for the other clones could someone post MFG spec pages for every other 4-stroke 49cc Clone that they can find?
From another website Honda 50
Honda Horizontal OHV Engine — 50cc, GX Series, 5/8in. x 1 1/4in. Shaft, Model# GXH50UQXA
The Honda 50cc GX Series OHV mini commercial-grade engine is designed for the most demanding commercial applications. It has set an industry standard for reliability and durability.
Overhead Valve design offers cooler, fuel-efficient operation and cast iron cylinder sleeve provides longer service life. The GX is reliable, easy starting and quiet running. Meets EPA and CARB emission levels standards. This legendary engine has earned the reputation as the preferred engine for construction equipment.
Designed for high-RPM applications.
Honda 50cc GX OHV air-cooled, 4-stroke, horizontal engine Horizontal Shaft: 5/8in. x 1 1/4in. tapped 1/4-28
Applications: high-RPM Historical rating 2.5 HP CCW Rotation
Fuel Tank Capacity: 1.21-qt. Oil Capacity: .63-qt. 7800 RPM
Recoil Start Transistorized magneto ignition
Approximate Mounting Base Dimensions: 4.4in. x 2.1in.
Flange Mount Bolt Circle: 4.17
PTO Height: 3.35in.
Low Oil Alert™
Semi dry element air cleaner Automatic decompression for easy starting
Heavy-duty ball bearing supported crankshaft
Cast iron cylinder bore
Double walled heavy-duty tank with in tank fuel strainer
Manual throttle and choke
Remote wire throttle and choke conversion possible with additional components
Dimensions: 8.9in.L x 10.8in.W x 13.9in.H
This was all jammed together, I opened it up to be more easily read.
Who can post H-S and others?
Mike
www.simpsonmotorbikes.com
Home of the 08 Racer and
NEW Model 10 production bikes
