I'm bored and thinking today I'll try to run the bike on methanol fuel just for grins. I'll mainly be drilling out the main jet and if I need to adjusting the needle I'm going to use a syn/Castor oil mix at 32 to 1. I don't expect to be able to go any faster but I do know I'll be burning more fuel the big draw back is the alcohol with attack the aluminum parts and probably attack the seals so after playing with the alcohol I'll need to drain the alcohol and run gas through it with the main jet drilled to alcohol it will run pretty sorry on gas if at all so I may just drain the float bowl and inject it with some wd-40 and pull the plug and pedal it around to clear it of the alcohol. Well I got to call Ilikeabikea so he can join in the festivities.
I don't recommend anyone doing this to their bikes as the alcohol fuel will eat up your engine. After I find the right size mainjet dia. I could run the $15.00 to $20.00 a gallon model fuel with nitro and burn it right to heck up.
