Old 06-28-2008, 01:41 AM
MotorbikeMike's Avatar
MotorbikeMike MotorbikeMike is offline
Dealer
Default Re: GXH50 vs Chinese Clones
Hi Guys, thanks for the comments. I still want as much more info as possible. Due to some of the responses here, I have learned a couple of interesting things.
#1 the little clones, though nice (I have one), are rated 1.5 hp
#2 The Honda (more money, tho well made) is rated 2.5!!!!
IMHO an increase of .5 hp is major for what we are doing, wouldn't people here pay good money for a carb, or a pipe that would deliver .5 HP?
I'm excited, a full horse is an amazing bonus! Soooo... this morning I ordered a gx50 from small engine warehouse. I have a grube gearbox from an earlier deal, and I have this little bike (see pic below). I think I have put on a front brake, if not, I surely will.
This little bike did a solid 30mpg, with JL gearbox, and the 1.5 Hua Sheng. I had set it up with the 44, which will not be appropriate for the Grube box? I always pedaled off the start, but when I let people test ride her it seems they NEVER did, tho I had told them to! It did, however, croak VERY early, some sort of a GB failure.
I am not up to date on the mix in the gearbox, for the JL the mix that had worked best was, packed with pale yellow Hi-Temp Disk brake grease (automotive), and then, when she started chattering, I found that if I mixed some SAE 40wt with the DBG, it would licquify into a very nice slurry which would continue to melt down, and continually lube the clutch, without bubbling out of the vented bolt at the rear of the box like the stinky 90/140 Hypoid did.
My goal is NOT to do the Grube box as a final, but to compare the H-S with the JL, to the Honda with the Grube box.
I know about searching, but since this thread is about the 4-stroke, and I'm adding (temp only) the grube, how would you guys suggust to set it up?
I probably have a 50th sprocket around here, but never had a larger one, and I can still make the same mix?
Mike
www.simpsonmotorbikes.com
Home of the 08 Racer and
NEW Model 10 production bikes
