Old 06-25-2008, 06:32 PM
Jemma Hawtrey's Avatar
Jemma Hawtrey Jemma Hawtrey is offline
Default Re: New S T R E T C H....Micargi Mustang GTS
Originally Posted by RedB66 View Post
The connection into the air cleaner is Nitrous. I connected the air cleaner by mounting 2 large (same circumfrance as carb) washers onto the carb and then mounted the rubber fitting from air cleaner over them. Tightened down with existing clamp.
Interesting that you've nitro'd the chengine - what performance increases have you noticed and how have you solved the lean-out problem ?
I love the frame, do you know if there is a UK supplier for it?
Jemma xx
