Old 06-20-2008, 08:44 PM
RONNY_ODELL's Avatar
RONNY_ODELL RONNY_ODELL is offline
Motorized Bicycle Builder
Default Re: First Build Is Up And Running Well....
WELL to be all honest Dax... it came from you .... i guess you can tell yours from ohters huh ? any way its doing good so far with very little issues. only problem i have had so far it the clutch handle bolt came out .... (easy fix) that and keeping all the guys at work off it ( hard fix ) only got about 25 miles on it so far..... caint open it up yet,,,, but i think it will run much better with a 03 to 1 ratio in it and be able to find the "sweet " spot on the throttle.... i plan on porting the exhaust pretty soon so the air flow goes better ... feels like it has it holding it back,,, but man i really like this motor... i plan on putting it on a moon dog later.... thia is the 70cc kit ... think ill go with a bigger sproket next time ,,,, as this kit goes plenty fast enough at half throttle so ill get a 40 tooth next time for better pulling on hills ... yall be good till next time
