  #12 (permalink)
Old 01-28-2008, 12:40 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: The clutch.
Do this only if there is no extra cable hanging off the actuating lever on the engine the outer housing is too long and you will need to take the cable apart. cut off an inch off the outer housing and reassemble and then adjust you clutch. If you've got some extra cable hanging on the end of your actuating arm loosen the nut on the cable ferrell and get a little slack that way. When and if you cut the outer housing be sure to pull the inner cable clear out don't need the inner one chopped off. One of my bike does have a little drag when the clutch is in the locked button position but when the lever is pulled in all the way there is no drag on the clutch. Rufus says I got to get back to building the headlight housing mold so good luck.
