You don't need to remove the small gear to adjust the clutch I did it just to show how to remove the gear. Leave the small gear on to adjust the clutch.If the big gear and the small gear will spin and the clutch lever is let out and the engine will not spin but like I said all the rest of the stuff is spinning, the little woodruff key has bit the dust and now you will know how to remove the small gear to fix it. To get under the driven parts which I've not done yet remove the nut that holds the driven parts and then you are on your own.
Ok put the gear back on and use a hammer type impact wrench like I did in the beginning ( $6.00 @ harber freight) to put the screw back on and you need to make sure the woodruff key was in place which you can seat it in its slot with a (BRASS punch) so you don't mushroom the key. There is a locking star washer under the screw to lock it in place so you should not need any loctite but if you've just got to do a little booger and not a big snotty wadd.
Rufus says don't forget the little dab of grease to lube the gears and don't over do it. Put the cover on with a gasket and go ride.Woops! Ruf said to check the operation out of the clutch before you button it up for good but to play it safe put the cover on with 2 screws to test as Rufus hates it when his tail gets in moving parts. He sure as heck will turn loose the flying monkees if he get his tail hurt and that really scares me.
THE END
