Old 01-27-2008, 10:49 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: The clutch.
you only need to turn the flower nut with your fingers to adjust and not a big friggen socket and breaker bar pull in and lock the clutch lever use your finger its easy. Some of the shade tree mechanics need to be forced to sit only under the tree and not touch tools by the way I am a shade tree mechanic of the red oak variety.
make since ?Don't burry the flowernut just get it started and release the clutch lever and see where you are then keep turning it in until when you test it it'll not slip? Did that sound right?
what else can I do to confuse you and me?
