Re: Overheating Engine Quote:
Originally Posted by stude13 you can start the motor, let it idle, then squirt some starting fluid ( wd40 ) at the junction of carb tube and engine, try wiggling the carb at the same time. if there is a leak the engine will rev up. | ...or want to quit, depending on what you use....either way it will tell you if you have a leak without removing anything.
