  #14 (permalink)
Old 06-11-2008, 07:26 PM
tinkerfinger's Avatar
tinkerfinger tinkerfinger is offline
Motorized Bicycle Builder
Default Re: Kill switch and light question
I understand what you are getting at. No, you can not use both hot wires off the magneto as the + side connection, and ground on frame. The 2 hot wires are technically two different ends of the same wire that is wrapped around a coil. As the mag turns, it charges the coil, connecting the two together is a no-no.
P.S. hooking to two seperate batteries like this would double amps and voltage. doing it to a coil will not, because both wires share the same source.
If your not sure, ask a friend first!
