  #10 (permalink)
Old 11-28-2009, 06:52 AM
Creative Engineering's Avatar
Creative Engineering Creative Engineering is online now
MANIC Mechanic
Default Re: Grubee/Skyhawk ??
Originally Posted by Hajuu View Post
oh awesome I just checked out those animations, thanks so much Creative Engineering.
It would definately explain why the lever feels entirely disconnected: because it is, because the clutch shaft isnt sticking out far enough.
My only question would be as to the bearing size, I guess as long as its as wide as the shaft slot then I cant go too wrong, but id assume that itd be important that it wasnt too far forward or back
I'll check it out as soon as I can get some replacement bearings. If anyone knows the size or even approximate, please let me know, cause ill just be buying many random ones and seeing what works best.
Cheers guys.
There's no need to try random bearings.
The original was 8mm. A 5/16" ball is .0025" smaller, and a lot easier to find. You will never notice the .0025" difference in diameter.
If you check the area where you did the assembly, you might find it. It's common for it to fall out and go unnoticed.
Jim
