Old 11-26-2009, 06:30 PM
RecycleBill RecycleBill is offline
Default Re: Heavier flywheel for more tractability
It might be that you could add weight to the clutch assembly and get the same effect as a heavier flywheel. Of course you'd then risk having main bearing concerns but that might also be true with anything that adds rotating weight to the crank assembly.
-RecycleBill, Greensboro, North Carolina's EZM dealer http://www.EzGreensboro.com
