Old 11-26-2009, 10:01 AM
azbill's Avatar
azbill azbill is offline
Default Re: List of gearboxes
I've been trying to compile a list of 4 stroke gearboxes available on the market. I'd appreciate one of the more experienced members to make a list thats more accurate.
"Hoot."- Seems like theses are the most available but also the cheapest and least durable. There have been numerous threads describing complete failures after a short period. There are two types, first version is a gear mesh and an updated version uses a chain
Grubee Stage III and II gear box- These are better that the Hoot but are noisy and the engagers break. It is a gear mesh and the box is filled with oil which some say causes more friction
Grubee G4. This is the latest Grubee gearbox. Its belt driven and available with and without an engager. There have been some bad reviews about this box being too wide and the freewheel breaking. Regardless I'm planing on buying the box from Spooky Tooth cycles when they get them in. Roland is a good guy I'm sure he'll help me out if it breaks.
EZM Q-matic - claim to fame is that its all american. the box was designed by "Quenton Guenther." The claim is that its the best box on the market but you have to pay for it. It's quite expensive. I think EZ MOTORBIKE COMPANY makes two types, one with a manual clutch and one with a centrifugal, not sure which is which. Helmutt cycles is using this box with a belt drive http://motorbicycling.com/f37/ezm-q-...ted-12773.html
the EZM 'Q-Matic' is a automatic with a max-torque made centrifugal clutch
the EZM 'Silent-Drive' is a manual version
both are a belt drive primary and chain secondary design (although, as mentioned, the manual is easily converted to a belt secondary)
I forgot to mention...
at this time, the manual 'Silent-Drive' is only available with a kit
the auto 'Q-Matic' is available in kit form or as a stand alone replacement for Honda GXH50, and HuaSheng 142f as well as a few other 4cycle engines with a 5/8" drive shaft
Firebelly hardbox- This one is also expensive (350) and I don't think there are any to be had. I've never been able to log on their website firebellycycles.com/ and the only info I found on it was off this forum. FireBelly 4 Stroke "Hard Box" Transmission. They even advertise on this site.
Sick bike parts shift kit
- I'm not sure where I read it but I think SBP is using a Firebelly hardbox to make a 4 stroke shift kit. If its performance is anything like their 2 stroke shift kit, then It'd be worth the money.
Staton- Staton-Inc motorized bicycles, bike kits & gear drive kits. I don't know much about this box but I've heard its good. Its a Gear mesh that's machined in the US. they sell a Nuvinci CVT kit that looks really cool. the box is intended to mounted on a rack.
Please, Please add to this list. Please mention each box in your reply so that It can be a running list and someone won't have to search this entire thread for a complete list.
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Last edited by azbill : 11-26-2009 at 04:50 PM. Reason: added even more EZM info :)
