Re: The Ultimate Hub for Direct Sprocket Bolt Up HI Roman415,
You are correct....Our sprockets come pre drilled to mount in place of the disc brake as well as being able to use the standard HD 9 hole mounts....Some bikes may have chain line issues when using the disc mount option (can sometimes be overcome by re dishing the rear wheel or using spacers etc...) but the 9 hole mount is always an option....
Hope this helps you.
Andrew |
