Thread: Summer contest
  #9 (permalink)
Old 06-02-2008, 06:02 PM
toyota4x4 toyota4x4 is offline
Motorized Bicycle Apprentice
Default Re: Summer contest
after this i had to make the gas tank what i did was i used a die grinder and a bench grinder to notch the bar so that it will fit nice on the neck. i then notched the other end of the bar so that it will fit on the bmx tube. what i mean by fit is that the opening of the tube touches the other tube so that i can weld it without having a gap. so i welded the first bar on the neck and the bmx bar to the one that is connected to the neck.
the shock that i have is off a mini quad. it is so that it bolts on the top and the bottom what i did was get two thick peaces of metal the same length and drilled a hole in them both at the same time so that the holes will be straight. i welled them on making sure that the shock fit in between them.
i then took a square bar and cut it in half so that i can weld that to the frame drill holes in them and put the shock on. my bike was almost ready to run so i decided i wanted to test it out. i put the grips on the ignition box on exhaust exc. one problem i had was the carb did not fit with stock manifold so i had to make my own. what i did was make a flange out of sheet metal and weld a bent bar on so the carb stuck out the side. the tank was not done so i rigged up a water bottle for the gas tank. i did this because i already cut up the other gas tank for the petcock and cap.
i took it for a ride and it worked!!! it was slow but the engine was not broken in yet so that is normle.
