Thread: Engine Whinning
Old 06-02-2008, 07:20 AM
Bikeguy Joe's Avatar
MODERATOR
Default Re: Engine Whinning
Go easy on that grease killer! It will work into the big gear after a few miles. If you get too much on them, it will get in the clutch then you'll have to clean it out.
Some bicycle motors whine more than others. I had one that made more noise than the other two put together.
As for your gear, that looks about normal to me. I just took one of mine apart to check it and it looks the same as yours.
Now, interesting story, even though the engine I just took apart has well over 500 miles on it, there is grease I put on the gears when I put it together at 0 miles and it is still in between the gear teeth like the engine has never been turned over! I guess thats the precise tolerances we are dealing with here!
