Old 11-12-2009, 02:21 AM
DonnnN's Avatar
DonnnN DonnnN is offline
Default Re: First MB Build. Help Needed.
When your stopping do you disengage the clutch? You need to pull the clutch in if not the engine will die when you go very slow or stop..
Also an air leak might also be your problem for your second question.. Or its just new and needs to be broken in before the power really kicks in..
Ok try this.. To check if you have an air leak..
Ok.. First i want you to start your engine like you normally would and then pull the clutch in and then let the engine warm up for about 5 minutes.. After that pull your choke lever all the way up.. THE engine should die immediately if all is well..
Goodluck with your engine.. Hope i helped..
