Old 11-01-2009, 07:52 PM
silverbear's Avatar
silverbear silverbear is offline
Default Re: Centrifugal Clutch
Originally Posted by VermontCruizer View Post
Does anyone know if there is a 2-cycle kit that uses a Centrifugal Clutch instead of the normal handle bar clutch system? Thanks!
I have one I got from BoyGoFast. I've only put a hundred miles on it and am now closed down for the winter for any riding. No trouble so far and I like it. It is hard to explain, but you still have a manual clutch which I use for when I pull start. You can also peddle along and let out the clutch to manual start, rev it a bit and the automatic clutch grabs hold and away you go. Coming to a stop you have no need to use the clutch at all. Nice.
SB
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
