  #17 (permalink)
Old 05-29-2008, 07:07 PM
deacon's Avatar
deacon deacon is offline
Default Re: Summer 2008 contest!
The ebike is done but i pulled it apart to work on the weed wacker again. I needed the drive wheel made from an 8" scooter back wheel assembly. This is my best and I hope last try at a weed wacker.
Couple of interesting things.
1. I'm mounting a sprocket (when and if it arrives) onto the weed wacker engine. going to have it chain drive to turn the 8" wheel. Since there is a large sprocket on the 8" wheel, I have no idea what kind of speed I will get if any.
2. I finally figured out a clutch mechanism for the rear engine. It consists of my wife broom handle, (We won't mention that to her just yet) and a brake cable.
Im still working on the throttle. If and when the front (engine) sprocket arrives... I should be able to test it after only a couple of hours more work.
Talk about a long project it has been a mess i'm telling you lol. It has also kept me sane (or maybe insane) for months.
By the way there was some talk once about a two cycle running backwards, Well I can tell you with a fair amount of certainty that the craftsman weed eater will not run backwards. I tried to start it backwards with no luck at all. It did start right up when I pulled it the way it was designed so I guess it has to do with the spark timing.,
