Re: leaking gasoline I had the same problem. I went out and got some rubber gasket material at the hardware store (used to make pump gaskets), cut it the same as the original gasket, and put it over the original gasket and it helps. I also drilles a very small hole in the top. The gas caps are junk. Keep your tank less than 1/2 full and you should be OK... |
