Old 10-18-2009, 03:46 PM
Ron-P Ron-P is offline
Default Re: How do I fix a broken motor mount?
Originally Posted by marts1 View Post
I don't see how it could be in the motor.
What I meant is that it appears to be broken off right at the point where the motor housing meets up with the bracket that holds the motor to the frame.
Thanks Norman, I'll remove the other bolt and pull the bracket out and see where the bolt snapped off. Hopefully you are right and there's enough bolt sticking out for easy removal. If not, I'm sure I could find a left-handed bit online (great suggestion by the way, thanks).
