Old 05-26-2008, 11:26 AM
cityevader's Avatar
cityevader cityevader is offline
Default Re: Listen Up Young & Old
Originally Posted by UVsaturated View Post
You do realize that gasoline is only flammable and not "explosive". So would you like to tell us all how a gas tank catching fire damages vital organs, unless of course it was the guys eye balls?
Actually, if you accumulate a large quantity of gas vapor in a contained area, at a perfect 14:1 ratio with oxygen, it will indeed explode quite readily if given an ignition source.
But your point is very valid...typically gasoline is in a way too rich environment, allowing only a portion of it to burn at a time. Very little danger at all throwing a match into a bucket of gas, at least until it melts and the liquid fire then spreads everywhere!
