  #76 (permalink)
Old 10-15-2009, 12:07 PM
camlifter's Avatar
camlifter camlifter is offline
Default Re: 3 speed jack shaft
prety sure the max rpm on the 35cc is 7600,
more gears dosen't mean more top speed, these little engines don't have the power to pull higher gear ratios. the 36T sprocket is about all a china girl is going to pull.
more gears in the lower under drive range will get you up to speed faster, no low speed bogging or jerking, or you could just pedal and be done with it.
www.acmemotorbikes.com
