  #14 (permalink)
Old 05-25-2008, 08:04 AM
Pablo's Avatar
Pablo Pablo is offline
Default Re: Ghost0's MB Cruiser
The engine mounts. Pretty easy. Here's what we currently have in the manual:
Step 10
Right side chain installation
Your engine should be loosely mounted to the frame at this point. The front stock mount should be very loose and the U-bolts on the rear mount should be just loose enough to allow the engine to slide along the seat tube.
1.Force the engine down as far as you can by pushing on the rear mount. Make sure the U-bolts are not getting hung up not allowing the motor to move.
2.Drape your new bike chain over the small sprocket with one end of the chain hanging about 4 inches down toward the rear of the bike. Wrap the remaining chain around the large chainring and up to meet the other end. Now you need to decide how much chain will need to be removed. It may be better to go too short at this time than too long, however never overly force the chain on, you can damage the chain and the freewheel..
3.Shorten your chain as required and install. The best method for this is to fully assemble the chain, place it inside the chainrings and onto the small sprocket. Once it is on the small sprocket, start placing it on the large chainring and slowly start turning the cranks until the chain has been installed. It will take some force to do this and your clutch on your engine will need to be disengaged so that the sprocket can rotate.
If your chain is loose after it has been installed, it may be too long. If it is only a little loose you may be OK, it needs to stay on with not too much slack but not be tight.
Adjust your rear mount to tighten the chain if it is a little loose. When you start running your bike, the force on the motor will twist it slightly and loosen the chain. You will find that you will probably have to adjust your rear mount 2 or three times until everything settles and the chain will remain tight. Remember to loosen your front mount substantially before trying to adjust your rear mount.
NOTE: never overtighten the chain, it can cause damage.
Tighten your rear U-bolt mounts and your front mount. Ensure that the chain remains tight.
Remove the set screws from the small sprocket, apply thread locking material and tighten the set screws.
