Re: Summer contest Today i took the engine and bolted it on to a different bike. i marked where the engine bolted on. i then took the engine off the frame and welded a bar connecting the two bars that the engine bolts on to. i did this because i want to have the two bars be straight so that when i line the engine sprocket with the rear sprocket on the tire i won’t have to deal with two separate bars. Today i also put my 35 tooth sprocket rear sprocket on the rear tire a good tip for doing this is to use a telescoping magnet to get the hardware on the bolts and a impacted wrench to tighten the bolts. |
