Thread: carb bowl leak
Old 05-22-2008, 08:26 AM
sisdavid sisdavid is offline
Default Re: carb bowl leak
My carb always leaks from time to time. I think it is because of that little pin that shuts of the fuel when the float is at the top. the adjustment is that little clip on that brass pin remember when you put your carb together? That is not what it is though. Maybe you could try adjusting your carb by bending those little brass things down that are on the top of your float. Just do not loose those little pieces if they fall out. Remember where they were before bending. That way can put them back if it does not work.
