Re: new hobby i think my choke disc may have been loose on the shaft, leaving it partly closed, when in the open position. i fixed the disc by squeezing the sides where the shaft goes through the disc. i noticed my plug was a kinda black, but dismissed it as rich break in mix. maybe this will fix my black goop problem. also had a stud break off from the back engine mount. i made one with a long shaft pegboard hanger, and a 6 mm x 1.0 die. so made a few more for spares. i could,nt find any metric allthread, so had to make due. what is the best material for bolts to cut studs from? hard, soft, what is the best to withstand the vibration from the motor? |
