Skiptooth sprocket question I had the good fortune of finding a pre war skiptooth 26" Schwinn DX cruiser at the dump the other day and as close as I can guess from reading up on it the year would be somewhere from 1940 to mid 40's. I'm been staring at it since figuring what to do with it since the frame and fork are really nice , the handlebar is in good condition and the seat just needs new leather and cleaning up. The DX was a budget model at the time, but still was a pretty cool bike. The tank is missing, fenders and chain guard as well. I sat an 80cc HT in the frame and it is tight, but I think with a slant head it will fit. I think I'd like to keep the bike pretty much original without going crazy with a real restoration and will be on the lookout for a chain guard, rear rack and tank if I can afford it. Here's where my question is regarding the pedal crank sprocket. It is a skip tooth and the wheels I intend to put on it are going to be modern heavy duty rims from bikeworldusa, 26 by 2.125. The sprocket is pretty cool and is called a "sweetheart" due to the heart shaped cutouts. Since it is a kind of signature thing with this model it would be nice to keep the sprocket even if I change the crank to something shorter to accommodate the engine clearance issues.Now, to the point... does anyone know if you can use a regular cruiser chain with a skip tooth sprocket and a wheel sprocket which is not skip tooth? I'm guessing not, but hoping you can. Or can I use a skip tooth chain if it will work with the wheel sprocket? Does anyone know? Since this will be a motorbicycle I don't anticipate a whole lot of pedaling, but it still has to be able to be pedaled.
Silverbear
Someday when I grow up I will probably lose interest in toys with wheels, but until then...
