loose\tight chain mick29 I have just boght a 40 tooth rear sprocket that bolts to a carrier on the rear wheels hub The carrier was machined to fit the hub exactly wich it does I spun the wheel to check the sprocket runs straight and true [ couldnt fault it ] fitted the wheel and chain but the chain still goes tight and then loose tight loose could it be the front sprocket? any ideas thanks mick29 |
