Old 05-19-2008, 06:33 PM
Saddletramp1200's Avatar
Saddletramp1200 Saddletramp1200 is offline
Smile A diffrent drummer
I found a 24" Schwinn mans bike & cut the tubes 2'' behind the seat post and
made the frame 25'' longer. Had to remove the top tubes & re-weld them. The
angle on the top tubes did not line up. I used new tube for all of it. It was not
easy but it went together well. Thanks to my welder friend Butch Mounted a steel plate drilled & mounted a HONDA 4.5 horse edger motor to it. Used an old clutch from a mini bike also the throttle. Still need a sprocket, and a chain guard I can make that. I used Bondo ( car body filler) to mold in the welds. It looks nice. May need a 26" rear wheel frame sits kinda low. The peddles clear the ground by 3". I don't think thats enough. Going to have to make the drive chains as they are not near long enough. I'm using the little white basket that came w/the bike for emptys
