Well I should say I started from scratch with a new twist shifter for the left side, rather than the dangerous thumbing for gears while power riding. The twist shifter installed really easy and running the cable through was fine, but the shifting turned out to be all hosed up. Only staying in one gear, then tweaking it and only staying in high, etc.....
So I took a time out and thought about it from some stuff Jim had told me about making sure there is some, but not too much cable slack in high gear and going from there. I readjusted the cable just so. Then set the H screw, set the cable tension medium roughly, then could get it to at least go all the way to low, then set the L screw, adjusted the cable tension more precisely. Shifting was getting much better. Fine tuned the H and L screws, then dialed in the tension. Lastly I adjusted the B-tension and fined tuned again.
Here's the easy version:
How To Adjust Your Rear Derailer - Bicycle Maintenance Video Tutorial
All I can say is the twist shifter is NICE!!
