Old 05-14-2008, 06:20 AM
Bikeguy Joe's Avatar
Default Re: I need help!!!!!!!
Unless there is crud or sand or ??? in there to really speed up the wear, nothing should loosen up if everything is tight and adjusted properly from the start. It is a bit tricky to get it right the first time sometimes and I know with a coaster brake you have to remove or grind down the dust cover one the engine sprocket side to clear the sprocket.
Better very slightly loose than too tight.
