Re: Bending exaust For the best results, fill the pipe with sand, heat it cherry red in an area about 3-4" long and bend it over a curved object like a big steel pipe or other steel object about the radius of the bend you want.
The sand reduces the possibility of kinking the pipe. You will ruin the chrome.
Some have bent the pipe slightly (less than an inch to clear the pedal crank of front fenders on some bikes) with no heat, if you want to try a moderate bend (under 45 degrees) without heat, still use the other steps above.
