Old 08-31-2009, 10:10 AM
Sydneysider's Avatar
Sydneysider Sydneysider is offline
Default Re: Brand New Kit - Clutch Squealing
theres a clutch pin that squeals when its dry and needs to be lubed now and then with grease. its inside the small sprocket wheel, take the clutch lever cover off, pin out, wipe clean and coat it with grease. careful theres a ball bearing that sits behind the pin, make sure it stays in there. if it falls out just clean it and pop it back in. that should stop the squealing for a long time..
