Originally Posted by ran49 |
It depends on if you're getting a 2 stroke or 4 stroke kit. From my experience with a 4 stroke mount, it appears the same as mine and the adjustable plate mount would work. I'm sure somewhere on this board, someone has probably figured the minimum and maximum clearances needed for a 2 stroke. There's no way there is too LITTLE room for a 2 stroke, so the main question would be if there is too MUCH room. If so, I assume you just use longer bolts and you can get spacers to fill in if there's too much clearance. I saw them on thatsdax.com. If I was going to buy another cruiser, the one you pictured would be the one I'd want.
